Hello Guest it is June 10, 2026, 07:23:55 PM
Author Topic: strange intermittent problem  (Read 7919 times)
« on: August 24, 2011, 05:53:51 AM »
I've just run my new lathe retrofit for the first time and there seems to be a problem
this is not the first machine I hve run Mach 3 on..  so I thought I knew what I was doing (famous last words !)
25Khz kernel  on a 3 gHz pentium 4 desktop machine with 1 Gig of ram running xp
set to always on, with no anti virus, network connection etc.
generic 5 axis breakout with CW8040 drivers on 4A steppers at 75Volts
when jogging at full speed on full travel of the axis as a test, 19 times out of 20 no problem at all
but every now and again the axis stops and the same kind of noise as a stalled motor is heard.
If this was on one axis, i would suspect a mechanical problem, but it happens on boths axis at about the same frequency at different places
if I take my finger off the jog momentarily, and reapply, the axis moves normally again
I have checked stuff like power supply voltages under load, and I only lose a volt or two
I have tried changing the step and direction pulse lengths, and I have tries increasing the kernel speed.
I have run the axis backwards and forwards by hand and they feel nice and smooth
any thoughts as to what to try next ?
Re: strange intermittent problem
« Reply #1 on: August 24, 2011, 06:26:35 AM »
Your motor tuning might be right at the critical point.
De-tune them by about 10-20% and see if it helps.
Russ
« Reply #2 on: August 24, 2011, 07:23:15 AM »
Thanks Russ,
I tried at 150%  current speed and 50% current speed and the symptoms were the same..
I went through the full optimisation steps and the problem is the same.
I have to go out for a while, but when I get back I will try without microstepping (set to 1/5 currently)
Its odd that it affects both axis equally, and with virtually no load on the axis
I may try a scope on the output of the breakout board, see if it changes during the stall..
Its probably something very simple
Chris
« Reply #3 on: August 24, 2011, 08:38:53 AM »
Could well be mid-band resonance....
