Hello Guest it is June 10, 2026, 12:35:18 PM
Author Topic: SIGNALS REALLY MIXED UP??? Please help  (Read 18876 times)
Re: SIGNALS REALLY MIXED UP??? Please help
« Reply #10 on: September 06, 2011, 02:27:59 PM »
Thanks for the explanation. For some reason, I can't find pulse width referring to anything but spindle setup. In Config, Motor Tuning, all I see is the Motor Movement Profile window having to do mostly with acceleration for the axis motors. Below to the right, there is a box for Step Pulse and Dir Pulse, both set at one as the docs recommend. They go from 1 to 5 and 0 to 5 respectively. Where exactly do I set pulse width?
« Reply #11 on: September 06, 2011, 02:33:21 PM »
That is the pulse width you are talking about, it can be set as high as 15 if I recall .
« Reply #12 on: February 10, 2016, 09:29:53 AM »
I am having the same problem with my Z axis it was running just fine for the first month that I had it but today during a cut the z axis motor started going crazy. I am pretty new to this this so please tell me where to change the pulse width? In the motor tuning settings there is a Step pulse and a dir. pulse where do I put the 15? in the step pulse or the dir. pulse? Also how do you enable Sherline mode? Thanks guys.
