Hello
Guest
it is
June 09, 2026, 11:43:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
new to mach - what can i expect?
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: new to mach - what can i expect? (Read 35849 times)
Carnoustie, Scotland
Re: new to mach - what can i expect?
Reply #30 on:
August 22, 2011, 04:28:10 PM »
Just really which pins things are connected to, for example which pin the X step is and which the X Dir is, which pins for E-Stop, limits etc.
farmertwingolf
Reply #31 on:
August 22, 2011, 04:32:04 PM »
Have that info now. Its 2-7. Just gotta tune the dugongs when my parallel cable arrives in the mail then configure mach then hopefully making chips
Reply #32 on:
August 22, 2011, 04:33:37 PM »
If you get stuck I am sure someone here will be able to help you out .
farmertwingolf
Reply #33 on:
August 22, 2011, 04:35:26 PM »
I seriously can't thank you enough for all the help.
Reply #34 on:
August 22, 2011, 04:36:23 PM »
no problem
farmertwingolf
Reply #35 on:
August 25, 2011, 05:36:10 PM »
Ok, finally have power on the c11 showing it is out putting to the hdbb board. The led lights on the drives are showing things to be good. I'm working on the servoconfigurator3 software to try to tune the drives. Not having luck and the drives aren't moving at all with mach in jog mode. Any suggestions? Thanks
Reply #36 on:
August 26, 2011, 01:30:42 AM »
If the DROs move in Mach when you jog then it is likely a hardware issue or possibly wrong pin assignment. Also check if the drives require an enable signal and whether you are providing it, could also be the same with your BOB.
farmertwingolf
Reply #37 on:
August 31, 2011, 06:31:18 PM »
I finally got the servoconfigurator3 software to move the servos and got them tuned. Still having an issue getting mach to move the servos though. I have checked the pin assignments and they are good. Don't know what else to check.
Reply #38 on:
September 01, 2011, 01:00:06 AM »
I answered in your other thread.
Print
Pages:
1
2
3
4
Go Up
« previous
next »
