Hello Guest it is June 11, 2026, 12:46:51 PM
Author Topic: News for plate burners(;-)  (Read 6511 times)
« on: August 18, 2011, 05:35:47 PM »
 I have been testing a cutting design program called MAKE THE CUT is is a vector cutting program used in the crafting, vinyl ,paper cutting world.
My wife and daughter use it for crafting with a CriCut. I was watching them work and noticed they were doing the same things I did for plasma only they did it 10 times faster than I could and in some cases did a much better job of it.
SO after a little studying and testing it is a VERY nice program that CAN be used in plasma design work. It outputs in several of the native Vector modes and it is possible that they could write a plugin to output it in DXF format as well.
I take it from SVG straight into Scam.
Might be worth a minute to check it out, the price is VERY reasonable. and the support seems top notch.
Just a thought, (;-) TP
Re: News for plate burners(;-)
« Reply #1 on: August 19, 2011, 07:55:46 AM »
FlexiSign also works very well, and outputs a good quality DXF.  Most of my drawing is technical in nature, so I mostly use Rhino.  The full blown version is expensive, but they have a version called FlexiStarter for $99.
