Hello
Guest
it is
June 11, 2026, 02:20:04 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
MACH 3 STOPS DURING WORK
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MACH 3 STOPS DURING WORK (Read 8031 times)
cicothemajstor
3
on:
August 18, 2011, 05:49:33 AM »
Hi everybody , what is the best procedure to do when I during work (cuting) on my cnc router recieve message on my MACH scren that "the limit switch is trigerred" , normaly the machine stops . But the machine not realy triggered limit switch , I think that is because some electric noise occur from time to time . Now my question is how to continues with work . I try simply to resset the warning on the screen and pusch the start button again . But that do not work very god . It is look like a some stepps missing between last stop position and new start ? What I can do ?
Thank for your help .
Carnoustie, Scotland
Re: MACH 3 STOPS DURING WORK
Reply #1 on:
August 18, 2011, 06:01:41 AM »
You would need to rehome, scroll to the line you want to start from then use the Run From Here feature.
Tweakie.CNC
9,356
Super Kitty
Reply #2 on:
August 18, 2011, 06:55:29 AM »
To prevent future problems it may be a good idea to fit a 0.1uF capacitor between each switch input and GND on your Breakout Board. This trick seems to have cured the electrical noise problems of quite a few in the past.
Print
Pages:
1
Go Up
« previous
next »
