Hello Guest it is June 11, 2026, 12:42:39 AM
Author Topic: Ignore Z  (Read 8153 times)
Ignore Z
« on: August 16, 2011, 03:35:09 PM »
Is there a way to tell Mach to ignore all Z moves?  For instance, if I wanted to run a program but just cut air with no Z moves.  Rather than generating a separate program with no Z moves, can I just do it in Mach with a setting?
Re: Ignore Z
« Reply #1 on: August 16, 2011, 03:37:59 PM »
Disable the Z axis and it will just ignore it I think.
Re: Ignore Z
« Reply #2 on: August 16, 2011, 04:21:48 PM »
Setting Page top right inhibit axis
OR I f you don't want to loose position of Z. Then set Z scale to .00001.  It will move but not so that you would notice it.
If that doesn't work for you there may be more options with CB.
Re: Ignore Z
« Reply #3 on: August 16, 2011, 04:57:36 PM »
The CB option is DoOemButton(252) same as the setting screen button
Hope that helps, (;-) TP
Re: Ignore Z
« Reply #4 on: August 18, 2011, 07:00:23 PM »
Just got around to trying this.  Worked great.  Thanks for the tip.
