Hello Guest it is June 09, 2026, 07:02:32 AM
Author Topic: Limit switches and reversal of Axis  (Read 6892 times)
Offline hhr08
  •  27 27
« on: August 16, 2011, 11:53:32 AM »
When limit switches are triggered Axis changes direction---also keyboard short cut keys reverse and controls button flyout Jog buttons reverse on many instances.  When trying to jog off limits it moves about 1/2 inch stops, get Limit switch trigger message then try to jog off again and get reversed direction. What setting is causing this crazy problem?  Also how can I save all of my settings from one day to the next without leaving my system on 24 hours a day?  Can MACH 3 be changed or modified to insure that all the last previous setting will be the  default or current setting when opening the application?
Re: Limit switches and reversal of Axis
« Reply #1 on: August 16, 2011, 01:16:31 PM »
Settings should not change like that, seems there may be a problem with your xml, can you attach it and I will have a look and see if the issue can be found.
Offline hhr08
  •  27 27
« Reply #2 on: August 17, 2011, 11:45:51 AM »
Hood,
Im in the process of cleaning off M3 and doing a clean install and if i have further issues I'll be back in touch.
Thanks much
