Hello Guest it is June 10, 2026, 01:57:17 AM
Author Topic: My Mach3 shows no reaction on inputs  (Read 30740 times)
« on: August 15, 2011, 02:04:40 PM »
Hey,
I Built my own cnc Machine. The signals go over 2 LPT Ports. The problem is, the first Lpt port works normal, but the seccond Port only sends output signals, but shows no input signals. I tested with my voltmeter the Voltage of the input pins on Port 2 (Pins 10-13  and Pin 15). The Voltage was switching between 5V and GND, so the problem has to be in the software. what have i done wrong? I tested 3 days, but i could not find the mistake
I hope you can help me
Sincerly,
Michael
Re: My Mach3 shows no reaction on inputs
« Reply #1 on: August 17, 2011, 03:23:06 AM »
Hey,
Today i thougt the problem could be in "use pin 2-9 as inputs". I activated it and bridged the contacts with some cables, so that the input signals were going to the pins 2-9. but tere was also no reaction by the program to inputs.
Has onybody an idea?
Michael;)
« Reply #2 on: August 29, 2011, 01:50:54 PM »
Has nobody an idea???
