Hello Guest it is June 12, 2026, 03:08:29 PM
Author Topic: Profiles with different kernel speeds?  (Read 8034 times)
Offline Fastest1
  •  920 920
  • Houston, TX
« on: August 10, 2011, 05:03:09 PM »
Can I run different kernel speeds on different profiles? I notice that I have quite a few profiles and some are running different kernel speeds. I typically run the default of 25 but want to use a higher speed on an upcoming profile I will be tuning. Is there any problem with doing this? For that matter, could I run 2 similar profiles with different kernel speeds and get faster travels with the higher kernel speed?
Re: Profiles with different kernel speeds?
« Reply #1 on: August 10, 2011, 05:12:11 PM »
No problem at all as long as your computer is fine with the higher kernels :)
« Reply #2 on: August 10, 2011, 05:38:19 PM »
Also keep in mind, I believe you have to retune the motor tuning settings when setting different kernel speeds as well -  ;)
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #3 on: August 10, 2011, 06:01:51 PM »
Dave, I did assume that. I am just trying out some digital drivers. 5056D Keling
« Reply #4 on: August 10, 2011, 06:22:59 PM »
