May 28, 2012, 12:46:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Good Vendor for L Type Gearing
Pages: 1   Go Down
Print
Author Topic: Good Vendor for L Type Gearing  (Read 229 times)
ThomasCB21
Active Member
Offline Offline
If it ain't fun, don't do it!
View Profile
« on: August 09, 2011, 11:54:19 AM »
Hi folks,
I know this is probably not the place to ask.  I have been asking questions and I have been getting my plans together.  So my next question is,  "Who know of a good and reasonable (cheap, cheap goes the birdy! Cheesy ) vendor that sells L Type Gears? (these use a size 75 synchronous type belt)"  As always any information is greatly appreciated and adds to my knowledge base.
Chris
Global Moderator
Offline Offline
View Profile
« Reply #1 on: August 11, 2011, 06:13:16 PM »
Try MSG Industrial Supply as they may have plastic ones.
 Heck, make your owne from bar stock borrowed from a friend and make sure you get the cutter to go with the stock! Evil
You did say cheap cheap ........ Wink Smiley Cheesy Grin
ThomasCB21
Active Member
Offline Offline
View Profile
« Reply #2 on: August 11, 2011, 07:51:07 PM »
Thanks Rich, I'll check them out.  Say can I borrow some bar stock and the cutter?  Cheesy
Chris
Global Moderator
Offline Offline
View Profile
« Reply #3 on: August 12, 2011, 04:53:11 AM »
Sorry Chris,
Can't lend you anything....my friends do all my programming and machining.  Huh Wink
Pages: 1   Go Up
Print
Jump to:
