Hello Guest it is June 09, 2026, 01:53:38 AM
Author Topic: Good Vendor for L Type Gearing  (Read 8172 times)
Offline ThomasCB21
  •  19 19
  • If it ain't fun, don't do it!
« on: August 09, 2011, 11:54:19 AM »
Hi folks,
I know this is probably not the place to ask.  I have been asking questions and I have been getting my plans together.  So my next question is,  "Who know of a good and reasonable (cheap, cheap goes the birdy! :D ) vendor that sells L Type Gears? (these use a size 75 synchronous type belt)"  As always any information is greatly appreciated and adds to my knowledge base.
Chris
Re: Good Vendor for L Type Gearing
« Reply #1 on: August 11, 2011, 06:13:16 PM »
Try MSG Industrial Supply as they may have plastic ones.
 Heck, make your owne from bar stock borrowed from a friend and make sure you get the cutter to go with the stock! >:D
You did say cheap cheap ........ ;) :) :D ;D
Offline ThomasCB21
  •  19 19
« Reply #2 on: August 11, 2011, 07:51:07 PM »
Thanks Rich, I'll check them out.  Say can I borrow some bar stock and the cutter?  :D
Chris
« Reply #3 on: August 12, 2011, 04:53:11 AM »
Sorry Chris,
Can't lend you anything....my friends do all my programming and machining.  ??? ;)
