May 28, 2012, 12:29:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  GCodes and editing files
Pages: 1   Go Down
Print
Author Topic: GCodes and editing files  (Read 203 times)
hhr08
Active Member
Offline Offline
View Profile
« on: August 01, 2011, 04:48:40 PM »
COUPLE OF QUESTIONS:
1.where within the Mach 3 file system can I locate and review the Default G Codes as they appear in the upper right of the menu screen?
2. have there been any updates to the Mach3 software in the last three to 5 months?
3.how can I manually edit Machine Coord under the Diagnostis menu/screen and
4. under the Offsets menu/screen how can I manually edit the Part offsets?
BR549
Active Member
Offline Offline
View Profile
« Reply #1 on: August 01, 2011, 05:01:27 PM »
(;-) Thank You
1.  Do you want to access the Mode message line OR do you want to see the reference of what the gcodes do?  I don' think you can access the Mode line and you can see the Gcode references ON SCREEN by pressing the Gcode button lower left hand side of the main page(program Run)
2.  You need to look at the download page and read the updates section to see what and when things were done to the versions. That way you get fresh info.
3. You cannot edit the Machine coord base the only thing you can do to it is Reset it to zero based on your current position(not recommended)
4. You edit the table and tool offsets in the Tool table and the Fixture offset tables in CONFIG  OR through Gcode calls. You can also modify the CURRENT Fixture offset from the offsets page.
Hope that helps, (;-)TP
« Last Edit: August 01, 2011, 05:04:21 PM by BR549 » Logged
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #2 on: August 01, 2011, 05:03:09 PM »
Most are set with the way you have Mach configured, such as the CV /ExactStop IJ modes, Metric/Imperial etc
Check the change log on the Mach download page.
Homing sets machine coords and is the only way it can be done, well there is another way to zero machine coords via VB but really homing is the way to do it.
Click in the DRO type what you want and hit the enter key on your keyboard.
Edit
Oh well too slow in typing I see Cheesy
Pages: 1   Go Up
Print
Jump to:
