Hello Guest it is June 09, 2026, 05:30:07 PM
Author Topic: Wizards - Missing Background Images  (Read 7998 times)
Offline karl60
  •  2 2
  • Blairgowrie, Scotland
« on: July 30, 2011, 01:44:45 PM »
Basic MACH3 wizards were working OK but now the background images have disappeared - data entry boxes still work OK as does GCode generation.  Would someone please point me in the direction of a solution.
Many thanks.
Re: Wizards - Missing Background Images
« Reply #1 on: July 30, 2011, 01:53:55 PM »
Have you moved files from the bitmaps folder as I would think thats where they are stored.
Offline karl60
  •  2 2
« Reply #2 on: July 31, 2011, 12:05:29 PM »
Registered the software and the Wizard background images returned - strange.
« Reply #3 on: July 31, 2011, 12:07:59 PM »
Unless you reinstalled Mach then I cant see how placing the licence file in would make any difference especially as wizards work fine in Demo mode.but as long as you are back to normal then thats all that matters :)
« Reply #4 on: August 01, 2011, 03:45:18 PM »
I've noticed that occasionally the back ground image for a wizard will not load if I access it through the "last wizard" short cut.
