May 28, 2012, 12:20:18 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  spindle pwm pin assignment other then #2-#9?
Pages: 1   Go Down
Print
Author Topic: spindle pwm pin assignment other then #2-#9?  (Read 209 times)
qwerty2012
Active Member
Offline Offline
View Profile
« on: July 29, 2011, 11:38:17 AM »
Can I use pin #1, #14, #16 or #17 for Spindle PWM output properly at 1KHz base Freq.?
pins #2-#9 are high speed output but I couldn't find any information about timing of other outputs of mach3 in the documents.
Thanks...
BR549
Active Member
Offline Offline
View Profile
« Reply #1 on: July 29, 2011, 04:21:05 PM »
Last I knew ALL output pins are HIGH speed. They can run at the kernal Freq.
Just a thought, (;-) TP
qwerty2012
Active Member
Offline Offline
View Profile
« Reply #2 on: August 05, 2011, 02:15:44 AM »
thanks for your comment
Pages: 1   Go Up
Print
Jump to:
