May 28, 2012, 12:18:38 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  2nd Parallel Port PCI Card (Recommendations)
Pages: 1   Go Down
Print
Author Topic: 2nd Parallel Port PCI Card (Recommendations)  (Read 288 times)
Helicopterjohn
Active Member
Offline Offline
Seffner, Florida
View Profile WWW
« on: July 28, 2011, 07:06:13 AM »
I am currently updating my Shopbot PRT will all new electronics.
I wish to add a second Parallel Port Card to my Windows computer running XP (via a PCI Slot).
I would like to know if anyone here has installed such a card with success and what brand, make, model and vendor source they used to purchase it.  Associated cost would be nice if known.
John
Shopbot PRT 48 X 96  Gekco 203V drives, PMDX-126 Multi-Mode Breakout Board, PMDX-107 Isolated Speed Control, (2) Ea. PMDX-133 3-axis Daisy-Chainable Motherboard for Gekco 203V's, PMDX-2PARPCi Dual Parallel Port Card, Super PID Speed Controller, 2010 Screen Set, Solid State Relays for dust/coolant.
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: July 29, 2011, 11:27:00 AM »
The A25 is a reasonable priced card http://www.cnc4pc.com/Store/osc/product_info.php?products_id=250 from those who understand CNC.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Jackal
Active Member
Offline Offline
View Profile
« Reply #2 on: July 29, 2011, 02:58:38 PM »
John,
Here is one that seems highly recommended. I bought one from NewEgg, as Tiger Direct didn't have it.
http://www.machsupport.com/forum/index.php/topic,11300.0.html
I can't comment on it because my retrofit isn't far enough along.
Here is the Newegg link:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815166007
Hope this helps,
Jack
Everything is bio-degradable if you run over it enough with a lawnmower.
angel tech
Active Member
Offline Offline
View Profile
« Reply #3 on: July 29, 2011, 04:34:14 PM »
i've used a variety of different cards from the cheapest £1.99(far eastern origin) to a whopping £25.99(novatech), and they've all worked.
Helicopterjohn
Active Member
Offline Offline
Seffner, Florida
View Profile WWW
« Reply #4 on: July 29, 2011, 07:31:50 PM »
Hi Guys,
Thanks for your valued input
John
Pages: 1   Go Up
Print
Jump to:
