Hello Guest it is June 10, 2026, 09:51:20 PM
Author Topic: HELP, ALL OF THE SUDDEN NO MACH RESPONSE  (Read 11144 times)
« on: July 21, 2011, 09:42:30 PM »
HELLO, I HAD AN AUTOMATIC WINDOWS UPDATE OR A POWER SERGE AND NOW MACH IS NOT CONNECTED TO THE MACHINE. THE DRO DO NOT CHANGE  AND THE DIAG LEDs DO NOT LIGHT UP.  I HAVE PLENTY OF WORK AND THIS IS NO TIME TO MESS UP.  CAN ANYONE HELP ME. I AM IN INDIANAPOLIS, IN. USA.  IS THERE ANYONE OUT THERE I CAN CALL TO WALK ME THROUGH THE SETUP.  THANK YOU.  TONY ROGERS
Re: HELP, ALL OF THE SUDDEN NO MACH RESPONSE
« Reply #1 on: July 22, 2011, 04:38:20 AM »
If the DROs are not changing when you jog then its either you have a faulty keyboard, the Jog Control is switched off or you have no axis enabled.
If you attach your xml I can have a look and see if I can find an issue.
« Reply #2 on: July 22, 2011, 06:20:40 AM »
HI HOOD,  THANKS FOR LOOKING.  I AM PUPPING BOTH OF MY HAIRS OUT.  THANK YOU TONY
« Reply #3 on: July 22, 2011, 07:02:01 AM »
I HAVE 2 PCI LPT 2 & 3 PORTS THAT RUNS THE CONTROLLER. I ALSO THINK THE LPT ADRESSES CHANGED.  LAST NITE I HAD THE DROs CHANGING WITH KEYBOARD.  THIS MORNING THE DROs ARS NOT WOTKING
« Reply #4 on: July 22, 2011, 07:27:26 AM »
I have just tried your xml and when I jog with the keyboard the DROs change, if yours are not then it would seem to be an issue with your keyboard (assuming you are using the same xml)
andrewm
« Reply #5 on: July 22, 2011, 07:46:39 AM »
Please do not type in all Caps.
« Reply #6 on: July 22, 2011, 08:36:29 PM »
HOOD, THANK YOU FOR TAKING TIME TO REVIEW MY FILE. I DELETED EVERYTHING AND STARTED OVER WITH A MACH UPGRADE.  UNDERSTANDING THE PORT ADDRESS SYNTAX THROUGH MR OFF.  BUT I AM UP AND RUNNUNG, JUST NEED TO TUNE AND TWEEK.  THANK YOU AGAIN.  TONY IN INDIANAPOLIS, IN 46254 USA
« Reply #7 on: July 23, 2011, 04:47:41 AM »
Good you got it :)
« Reply #8 on: July 23, 2011, 05:26:54 AM »
AAASIGNCOM,
Good you got it
Well almost............turn the caps off please as it makes for easier reading and you won't wake the neighbors up when shouting..... ;)
