Hello Guest it is June 09, 2026, 01:59:50 PM
Author Topic: Mach3 and Small form factor PCs  (Read 9488 times)
« on: July 21, 2011, 02:09:44 PM »
I am just starting out in planning a CNC conversion of a small mill.
I don't have a lot of space in the workshop and so I'm thinking of buying a 2nd hand Dell sx280 which is 3Ghz P4 based machine with serial and parallel ports and would appear to meet/exceed the processing requirements of Mach3.
Has anyone used this Ultra Small Form Factor machine with Mach3 ?
Spec :  http://support.euro.dell.com/support/edocs/systems/opsx280/en/ug/specs.htm
My chief concern is that what ever the problem that Mach3 has with laptops (?) might also exist with these USFF PCs
Any help gratefully received.
TIA
Bob
Re: Mach3 and Small form factor PCs
« Reply #1 on: July 21, 2011, 02:45:26 PM »
It is normally the power saving features of Laptops that cause the issues and because Laptops are designed to run from batteries these are often very hard to disable completely.
I use Via Pico mobos in my lathe and one of my mills, they dont have parallel ports  but I use the SmoothStepper anyway so that doesnt concern me. I am also redoing the Bridgeport at the moment and I am using a micro ATX mobo. Although I am again using an external controller with this retrofit I did run the driver test at 100KHz to see what it was like and it is the smoothest I have ever seen on any computer at any frequency, so although I havent actually tried it with the parallel port I would be confident that it would be flawless.
The mobo is an Asus AT5NM10-I
« Reply #2 on: July 21, 2011, 02:51:50 PM »
Sounds hopeful then Hood!
Bob
Offline ERP
  •  35 35
« Reply #3 on: July 21, 2011, 09:19:02 PM »
I use an atom D525 based board which has a parallel port.
Works fine.
« Reply #4 on: July 31, 2011, 02:12:51 PM »
The GX270/280 has a known issue with blowing capacitors as well as motherboard problems.  I have a collection of them.  Never had a problem with the full size towers.
