May 28, 2012, 01:59:11 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  gCODE /eXCEL SPREADSHEET QUESTION
Pages: 1   Go Down
Print
Author Topic: gCODE /eXCEL SPREADSHEET QUESTION  (Read 334 times)
BR549
Active Member
Offline Offline
View Profile
« on: July 19, 2011, 08:07:23 PM »
I have an Excel spreadsheet I am working with and I need to work with 262 cells. I need to start at O and at each cell increase the value by .004267176 up to total number of cells.
 DOES ANYONE have a clue as to how to use a formula to do this?
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: July 19, 2011, 09:32:37 PM »
Terry, will fill series help?
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
Picengraver
Active Member
Offline Offline
View Profile
« Reply #2 on: July 20, 2011, 04:47:14 AM »
Enter 0 in cell A1
Enter =+A1+.004267176 in cell A2
click once on cell A2 to highlight it
Scroll down to cell A261 (262 cells)
hold down SHIFT - click cell A261
hold down CONTROL key - hit D
cell A261 should now read 1.10946576
Hope this is what you need.
John Champlain
Ya-Nvr-No
Active Member
Offline Offline
Scuptris 3D
View Profile
« Reply #3 on: July 20, 2011, 05:19:37 AM »
Here is a something that might work for you.
Lets you change either or both numbers to fill your table.
* br549-excel.xls (26 KB - downloaded 20 times.)
« Last Edit: July 20, 2011, 05:30:23 AM by Ya-Nvr-No » Logged
Ya-Nvr-No
Active Member
Offline Offline
Scuptris 3D
View Profile
« Reply #4 on: July 20, 2011, 07:16:18 AM »
Or you can do it using VBA in excel
gives you even more control
But you have to have macros enabled to use this feature.
* br549-excel-2.xls (98.5 KB - downloaded 17 times.)
BR549
Active Member
Offline Offline
View Profile
« Reply #5 on: July 20, 2011, 01:04:03 PM »
AH fill series did the trick. Thanks GUYS
Pages: 1   Go Up
Print
Jump to:
