Hello Guest it is June 11, 2026, 10:15:52 PM
Author Topic: gCODE /eXCEL SPREADSHEET QUESTION  (Read 10953 times)
« on: July 19, 2011, 08:07:23 PM »
I have an Excel spreadsheet I am working with and I need to work with 262 cells. I need to start at O and at each cell increase the value by .004267176 up to total number of cells.
 DOES ANYONE have a clue as to how to use a formula to do this?
Re: gCODE /eXCEL SPREADSHEET QUESTION
« Reply #1 on: July 19, 2011, 09:32:37 PM »
Terry, will fill series help?
« Reply #2 on: July 20, 2011, 04:47:14 AM »
Enter 0 in cell A1
Enter =+A1+.004267176 in cell A2
click once on cell A2 to highlight it
Scroll down to cell A261 (262 cells)
hold down SHIFT - click cell A261
hold down CONTROL key - hit D
cell A261 should now read 1.10946576
Hope this is what you need.
John Champlain
« Reply #3 on: July 20, 2011, 05:19:37 AM »
Here is a something that might work for you.
Lets you change either or both numbers to fill your table.
« Last Edit: July 20, 2011, 05:30:23 AM by Ya-Nvr-No »
« Reply #4 on: July 20, 2011, 07:16:18 AM »
Or you can do it using VBA in excel
gives you even more control
But you have to have macros enabled to use this feature.
« Reply #5 on: July 20, 2011, 01:04:03 PM »
AH fill series did the trick. Thanks GUYS
