Hello Guest it is June 09, 2026, 12:38:17 PM
Author Topic: Question about timer pump for oiler with override button  (Read 6807 times)
Offline Jackal
  •  173 173
« on: July 16, 2011, 10:23:35 PM »
I'm still chugging along. Getting  control panel together.
If I use a Mach3  brain for a timer that oils the ways every say "8 minutes". Can I also have a  temporary push button so that I can oil it a few times manually  on start up?
JAckal   :)
Everything is bio-degradable if you run over it enough with a lawnmower.
Re: Question about timer pump for oiler with override button
« Reply #1 on: July 17, 2011, 04:15:28 AM »
Yes, shouldnt be a problem, you could get fancy and probably have it resetting the timer as well but just having the button connected to the output in the Brain will do it.
Offline Jackal
  •  173 173
« Reply #2 on: July 17, 2011, 10:50:44 PM »
Thanks Hood,
I just didn't want the current to   back  feed  and burn something up.
JAckal :)
