Hello Guest it is June 09, 2026, 12:37:55 PM
Author Topic: Filpping the direction of the x-axis all by itself  (Read 21647 times)
Re: Filpping the direction of the x-axis all by itself
« Reply #10 on: July 18, 2011, 08:34:21 AM »
Does it always light up the SCALE led and change the scale setting when it happens?
« Reply #11 on: July 18, 2011, 12:53:43 PM »
Always.
« Reply #12 on: July 18, 2011, 12:58:11 PM »
If it is just one axis, try changinging the cables with one of the other axis, do an "air cut" a few times, and see if the X still does it. If it doesn't, it could be a wiring flaw.
I had this happen when building a system and it turned out it was 2 of the direction wires slightly touching each other.
Each wire has individually shrink tubing with no way to touch. I triple checked every wire before I plugged the motors in.
« Reply #13 on: July 18, 2011, 01:10:31 PM »
Can you attach your xml and some code that it happens with, will try to see if I can get it to do the same and maybe manage to work out why.
Here's the XML code. Looks like a jumbles up mess to me  ???
« Reply #14 on: July 18, 2011, 01:52:56 PM »
Have sent you a PM
