May 28, 2012, 01:52:56 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Breathing New Life Back Into a Shopbot PRT 48 X 96 CNC Router
Pages: « 1 2   Go Down
Print
Author Topic: Breathing New Life Back Into a Shopbot PRT 48 X 96 CNC Router  (Read 719 times)
Helicopterjohn
Active Member
Offline Offline
Seffner, Florida
View Profile WWW
« Reply #10 on: August 08, 2011, 09:43:04 PM »
I can say for sure what made the motors run so much smoother and quieter, but it was a welcome outcome.  Replacing the Gekco 202's with the Gekco 203V's helped I am sure.
John
Shopbot PRT 48 X 96  Gekco 203V drives, PMDX-126 Multi-Mode Breakout Board, PMDX-107 Isolated Speed Control, (2) Ea. PMDX-133 3-axis Daisy-Chainable Motherboard for Gekco 203V's, PMDX-2PARPCi Dual Parallel Port Card, Super PID Speed Controller, 2010 Screen Set, Solid State Relays for dust/coolant.
Helicopterjohn
Active Member
Offline Offline
Seffner, Florida
View Profile WWW
« Reply #11 on: August 19, 2011, 10:12:06 PM »
I installed the second parallel port card and it works great.  I have also made a dual outlet box that has 3 solid state relays installed.  I removed the connector tab on one of the receptacles so that each of the two outlets could be controlled by a separate solid state relay.  My current Mach3 screenset will allow me to click on an icon and toggle my dust collector and vacuum pump on and off.  I still have one spare that can be used for another device.
Here is a link that shows the solid state relays that I used.  They are rated at 25 amps.  http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=360385301485&ssPageName=ADME:L:OU:US:1123
John
« Last Edit: August 19, 2011, 10:19:18 PM by Helicopterjohn » Logged
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline Offline
View Profile
« Reply #12 on: August 20, 2011, 06:19:27 AM »
Hi John,
Even though you look like you're finished with your relay box, this is a nice writeup that adds some nice features.
http://www.cartertools.com/tbbrb.html
Dave->    Wink
Helicopterjohn
Active Member
Offline Offline
Seffner, Florida
View Profile WWW
« Reply #13 on: August 20, 2011, 07:17:17 AM »
Hi Dave,
Very nice link with great pictures and documentation.  Thanks for sharing.
John
budman68
Global Moderator
Offline Offline
View Profile
« Reply #14 on: August 20, 2011, 07:18:57 AM »
 Smiley
Dave->    Wink
Pages: « 1 2   Go Up
Print
Jump to:
