Hello Guest it is June 10, 2026, 04:35:44 AM
Author Topic: Just bought my first cnc, need some pointers/info please about getting started.  (Read 22159 times)
For the limit switches it's really up to you how you set them up. On my router I only use 3 optical limits, 2 lower limits for x and y and an upper limit for z. They all double as homing switches. If I had more when I bought it I would have put on both upper and lower limits, but again it's up to; most machines technically don't NEED any of them at all to function properly. (I'm not suggesting you shouldn't hook them up, though ;).
Sounds like you're on the right track!
Enjoy!
Chris
I modified the tool mounting bracket last night so I can mount the Bosch router but I need to pick up some longer screws for it. I hope today I can finish everything up.
Thanks again for all the help,
Chad
