May 28, 2012, 01:43:08 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Setting up remote START, STOP, PAUSE buttons
Pages: « 1 2 3   Go Down
Print
Author Topic: Setting up remote START, STOP, PAUSE buttons  (Read 588 times)
WidgitMaster
Active Member
Offline Offline
View Profile
« Reply #20 on: July 11, 2011, 08:10:34 PM »
When PCI card installed, it defaulted to LPT3
I have set it back to port 2, saved settings, and shut down MACH3
Now it actually works!
For some reason it was not updating the XML file?
Thanks again!
Eric
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #21 on: July 11, 2011, 08:15:05 PM »
What windows names the port has no bearing on what Mach calls it. In Mach you have Port 1 and Port 2 for parallel ports and the address set for each is what Mach looks at. So windows could call it LPT 1 and LPT 400 if it wanted but as long as you have the correct address set in Mach it will be Port 1 and Port 2 as far as Mach is concerned.
The changes you make will take effect immediately after a reset but will only actually be written to the xml on a restart of Mach.
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #22 on: July 11, 2011, 08:15:33 PM »
LPT3 is NOT Port3.
You get Two parallel Ports, and they are either assigned to Port1, or Port2. The LPT #'s don't mean anything to Mach3.
Pages: « 1 2 3   Go Up
Print
Jump to:
