May 28, 2012, 01:37:14 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  DC-03 DigiSpeed GX V3
Pages: 1   Go Down
Print
Author Topic: DC-03 DigiSpeed GX V3  (Read 229 times)
generlsocial
Holding
Offline Offline
View Profile
« on: July 07, 2011, 03:01:01 PM »
Hello Everyone,
I just got at DC-03 DigiSpeed GX V3 to control my chinese C02 laser. I want to use Mach 3 or EMC2.
Has anybody gotten it running? What is the wiring diagram? Which pins do you use on the parallel port?
Here's a picture of it: http://mambohead.com/2011/07/laser-controller-design/
I will get through it eventually but if someone already has it working perhaps they could share what they did?
Thanks in advance!
Darcy
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: July 08, 2011, 01:47:01 AM »
Darcy,
This is a pretty old thread but it is straightforward enough to connect the analog 0-5Volts to the laser PSU and it is again straightforward to setup the spindle control within Mach to output the PWM (do a search for PWM and you will find the details). This works just fine for vector cutting but if you decide to do raster work using the Impact/Laser Engraver plugin it all goes pear shaped.
There are more details in these threads (if you have a bit of time to spare  Cheesy );
http://www.machsupport.com/forum/index.php/topic,16446.0.html
http://www.machsupport.com/forum/index.php/topic,12444.0.html
Hope this helps,
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #2 on: July 08, 2011, 06:23:05 AM »
generlsocial - as Tweakie said, you ressurected a pretty old thread here so I've split it out and given you your own. Welcome BTW.
Pages: 1   Go Up
Print
Jump to:
