Hello
Guest
it is
June 12, 2026, 08:35:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
DC-03 DigiSpeed GX V3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DC-03 DigiSpeed GX V3 (Read 8190 times)
generlsocial
1
on:
July 07, 2011, 03:01:01 PM »
Hello Everyone,
I just got at DC-03 DigiSpeed GX V3 to control my chinese C02 laser. I want to use Mach 3 or EMC2.
Has anybody gotten it running? What is the wiring diagram? Which pins do you use on the parallel port?
Here's a picture of it:
http://mambohead.com/2011/07/laser-controller-design/
I will get through it eventually but if someone already has it working perhaps they could share what they did?
Thanks in advance!
Darcy
Tweakie.CNC
9,356
Super Kitty
Reply #1 on:
July 08, 2011, 01:47:01 AM »
Darcy,
This is a pretty old thread but it is straightforward enough to connect the analog 0-5Volts to the laser PSU and it is again straightforward to setup the spindle control within Mach to output the PWM (do a search for PWM and you will find the details). This works just fine for vector cutting but if you decide to do raster work using the Impact/Laser Engraver plugin it all goes pear shaped.
There are more details in these threads (if you have a bit of time to spare
http://www.machsupport.com/forum/index.php/topic,16446.0.html
http://www.machsupport.com/forum/index.php/topic,12444.0.html
Hope this helps,
stirling
2,188
UK
Re: DC-03 DigiSpeed GX V3
Reply #2 on:
July 08, 2011, 06:23:05 AM »
generlsocial - as Tweakie said, you ressurected a pretty old thread here so I've split it out and given you your own. Welcome BTW.
Razordance Torch Height Control
Print
Pages:
1
Go Up
« previous
next »
