May 28, 2012, 01:37:05 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  24 volt proximity switches
Pages: 1   Go Down
Print
Author Topic: 24 volt proximity switches  (Read 378 times)
wbleeker
Active Member
Offline Offline
View Profile
« on: July 08, 2011, 02:10:15 AM »
Hi Everyone I need some help
I am converting a Chinese router from DSP controller to Mach 3 , I have a BOB and speed control board from Peter Homann as well as the 5volt power supply for these, originally the machine was fitted with SN04-N 24 volt proximity switches which have their own power supply. I want to keep these and was advised to use an Opto22 G4PB4 board and G4IDC modules as an interface between the 24 volt side and the 5volt Breakout Board.
I am not the worlds most brilliant at electronics and cant seem to get the wiring set up that I get a 24v signal in one side and 5v out the other? Can someone give me some easy to follow directions please?
Will
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: July 14, 2011, 06:16:48 AM »
Hi Will,
If you take a look at this document (Section 7) it gives details of proximity switch connections for 12 & 24 Volt / NPN and PNP versions. http://cnc4pc.com/Tech_Docs/C10R10_USER_MANUAL_V2.pdf
Hope this helps,
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
wbleeker
Active Member
Offline Offline
View Profile
« Reply #2 on: July 15, 2011, 02:55:52 AM »
Thanks for that Tweakie, I think I have sorted it out now, on with the rest of the job!
Will
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #3 on: July 15, 2011, 03:30:19 AM »
Hi Will,
I am glad you have it sorted.
Don't forget to post some pictures of things you make once it is all 'singing and dancing'.  Wink
Pages: 1   Go Up
Print
Jump to:
