May 28, 2012, 01:27:10 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Marco gone wild.
Pages: 1   Go Down
Print
Author Topic: Marco gone wild.  (Read 555 times)
dfurlano
Active Member
Offline Offline
View Profile
« on: July 05, 2011, 05:10:20 PM »
Been struggling all weekend  trying to figure this out.
If I go to the offset menu and click the ref all home the Z,X,Y,A home with no problems.
If I click the button on my home page to run the macro below I get random behavior.  Mostly the Z rapids down but once in a while the Z will rapid up and then about half the macro will run.
If I open the macro using the edit button script command and run the macro line by line it runs flawlessly.
This system has been running with no issues for a few years.  It all started with a dumbass move on my part that crashed the system. The only difference is that I added the DoOEMButton command to the macro.
I also tried reinstalling Mach.
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
Code "G54"
Code "G90"
DoButton( 24 )
DoOEMButton 1010
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Code "G90 G0 Z-2.75"
While ismoving()
Wend
Code "G90 G31 Z-4 F4" 'probing move, can set the feed rate here as well as how far to move
While ismoving()
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
While ismoving()
Sleep 100
Wend
Code "G90 G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While ismoving()
Sleep 100
Wend
Zoffset = getvar(5223)
Cline = (ZProbePos+-3.2395) '-3.2395 Distance between center line of rotary and probe
SetVar(5243,(Cline+PlateThickness))'Set G55 Z
While ismoving()
Wend
SetVar(5263,(Cline+PlateThickness))'Set G56 Z
While ismoving()
Wend
SetVar(5283,(Cline+PlateThickness))'Set G57 Z
While ismoving()
Wend
Code "G91"
Code "G0 Z 0.1" 'retract
While ismoving()
Sleep 100
Wend
Code "G55"
Code "G90"
While ismoving()
Sleep 100
Wend
Code "G0 X0 Y0"   'move to start position
While ismoving()
Sleep 100
Wend
Code "(Z axis is now zeroed for G55, G56, G57)" 'puts this message in the status bar
Exit Sub
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: July 05, 2011, 05:33:32 PM »
Try This:
Sub Main()
Code "G54"
Code "G90"
DoButton( 24 )
DoOEMButton 1010
Sleep (250)
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
While ismoving()
Wend
While ismoving()
Wend
ZProbePos = GetVar(2002) 'get the exact point the probe was hit
Sleep(150)
While ismoving()
Wend
Cline = (ZProbePos-3.2395) '-3.2395 Distance between center line of rotary and probe
Code "G91"
Code "G0 Z0.1" 'retract
While ismoving()
Wend
Code "G55"
Code "G90"
While ismoving()
Wend
Message "Z axis is now zeroed for G55, G56, G57" 'puts this message in the status bar
End Sub
dfurlano
Active Member
Offline Offline
View Profile
« Reply #2 on: July 05, 2011, 06:24:24 PM »
It homes now but does not Zero the Z axis.  Also takes off in the Z and X at Code "G90 G0 Z-2.75"
dfurlano
Active Member
Offline Offline
View Profile
« Reply #3 on: July 05, 2011, 07:17:03 PM »
Got it to work!  Thanks for the help!  I moved the DoOEMButton and added a ismoving.  It would not take the Sub Main statement.
w00t!
Code "G54"
Code "G90"
DoButton( 24 )
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
While ismoving ()
Wend
DoOEMButton(1010)
While ismoving ()
Wend
While ismoving()
Wend
While ismoving()
Wend
While ismoving()
Sleep 100
Wend
While ismoving()
Sleep 100
Wend
While ismoving()
Wend
While ismoving()
Wend
While ismoving()
Wend
Code "G91"
While ismoving()
Sleep 100
Wend
Code "G55"
Code "G90"
While ismoving()
Sleep 100
Wend
While ismoving()
Sleep 100
Wend
Exit Sub
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #4 on: July 05, 2011, 07:20:11 PM »
DoOemButton 1010 should be
DoOemButton(1010)
I missed that.
When a macro messes up, sometimes it's a good idea to close Mach3 and reboot the PC, as macros may not run correctly again until you do this.
How about this?
Sub Main()
ProbeDepth = (GetOEMDro(802) - 4 ) ' Probe move to current Z - 4
Code "G54"
Code "G90"
DoButton( 24 )
DoOEMButton (1010)
Sleep (250)
DoButton( 23 )
DoButton( 22 )
DoButton( 25 )
Code "G0 Z-2.75"
While IsMoving()
Wend
Code "G90 G31 Z" & ProbeDepth & " F4" 'probing move, can set the feed rate here
While IsMoving()
Wend
Sleep(150)
Code "G90 G0 Z" & ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving()
Wend
Code "G91"
While IsMoving()
Wend
Code "G55"
Code "G90"
While ismoving()
Wend
End Sub
dfurlano
Active Member
Offline Offline
View Profile
« Reply #5 on: July 05, 2011, 08:54:46 PM »
Very true on the restart.  Thanks again for your help.
Sargon
Active Member
Offline Offline
View Profile
« Reply #6 on: July 06, 2011, 05:36:08 AM »
Are you sure about this? I've done a fair amount of programming in Mach3 and haven't observed this, and I have had scripts screw up (over, and over, and over, especially on the Egg Shape Wizard!). I always hit cycle stop a few times and reset twice and everything seems fine again.... What have your observations been?
I'm actually really curious because you have a lot of experience, certainly more than me!
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #7 on: July 06, 2011, 06:06:31 AM »
I probably should have worded that differently.
I've seen issues when having to estop during a macro, where the machine would no longer home correctly afterwards, just crashing through the home switches, and the macro would no longer run afterwards, until re-booting the PC.
I'm sure this isn't the case all the time. What I'm saying, is that if Mach3 doesn't appear to be acting correctly, then close it and re-booting should clear it up.
Sargon
Active Member
Offline Offline
View Profile
« Reply #8 on: July 06, 2011, 07:33:10 PM »
Thanks for the clarification Ger.
Have a great day/night!
Chris
« Last Edit: July 06, 2011, 07:34:59 PM by Sargon » Logged
Pages: 1   Go Up
Print
Jump to:
