May 28, 2012, 12:02:01 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Problem with set up
Pages: 1   Go Down
Print
Author Topic: Problem with set up  (Read 165 times)
Mumaharps
Holding
Offline Offline
View Profile
« on: July 03, 2011, 12:01:31 PM »
I have had to reinstall Mach 3 -- upgraded computer and OS, now have XPsp3. Thought I would upgrade to lateset version. Now after setting up a couple of times the  DRO's which are meant to be accurate show no relationship to my table. (CNC router). instead of 48 x 24 x 6 inches they are showing for a machine which is about 3 times larger. Never have had this problem before and see not solution.
Desperat to get back in business. Not a hobby type of guy--just want it to work again.
Roger
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: July 03, 2011, 12:43:55 PM »
If you command a move from MDI does it move the correct distance? If not then your steps per unit are likely set wrong.
Pages: 1   Go Up
Print
Jump to:
