Welcome, Guest. Please login or register.
Did you miss your activation email?
May 27, 2012, 11:57:39 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Tangent Corner
| |-+  Bargain Basement
| | |-+  MACH3, EMC2/ CNC Breakout Board, DB25/ Parallel Cable
Pages: 1   Go Down
Print
Author Topic: MACH3, EMC2/ CNC Breakout Board, DB25/ Parallel Cable  (Read 1320 times)
Robiz
Active Member
Offline Offline
JI Robotics
View Profile WWW
« on: July 01, 2011, 11:33:19 PM »
Multifunctional Board.
** MACH3, EMC2/ CNC Breakout Board, DB25 Parallel Cable **
** Description **
* For Mach3, EMC2
* 4 axis 1 Pulse(DIR, PULSE)
* Line Drive Output
* 5 Sensor Input
* 2 Relay Contact
* Charge Pump function
* +24V DC Power
* 50mA Current Consumption
* Spindle Speed Control - DC Voltage(0~10V)
* Vertical Parallel Port Connector
* Removable IN/OUT Connector
You can get detailed information below pdf-file
http://gahueyn.netii.net/CNC%20Board...Eng_Manual.pdf
Logged
JI Robotics
Robiz
Active Member
Offline Offline
JI Robotics
View Profile WWW
« Reply #1 on: July 02, 2011, 12:56:30 AM »
** Description **
* For Mach3, EMC2
* Line Drive Output
* 5 Sensor Input
* 2 Relay Contact
* +24V DC Power
You can get detailed information by pdf-file for free below.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180668247371&ssPageName=STRK:MESE:IT
Logged
JI Robotics
Robiz
Active Member
Offline Offline
JI Robotics
View Profile WWW
« Reply #2 on: July 02, 2011, 01:02:07 AM »
Pls.. Just look around the ebay page and you can obtain detailed information there.
  User Manual_PDF file
Thank you and have a great day !
« Last Edit: July 02, 2011, 01:11:53 AM by Robiz » Logged
JI Robotics
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
