Hello Guest it is June 13, 2026, 04:18:43 AM
Author Topic: Mach3 cannot send out signal  (Read 7819 times)
« on: June 27, 2011, 06:13:19 PM »
Hello,
I have a problem, I connected the serial port to breakout board, but when I run Mach3, there's no signal sending out through the breakout board, nor the serial port. Any one knows the reason?
Xiang
Re: Mach3 cannot send out signal
« Reply #1 on: June 28, 2011, 01:56:00 AM »
You need to use the parallel port rather than the serial port.
If you are using the parallel port then check you have the correct address set in Mach for it.
  •  9,356 9,356
« Reply #2 on: June 28, 2011, 01:57:27 AM »
Post deleted - I totally misunderstood the question.
« Last Edit: June 28, 2011, 02:02:17 AM by Tweakie.CNC »
