Hello
Guest
it is
June 13, 2026, 05:39:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 cannot send out signal
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 cannot send out signal (Read 7820 times)
renxiang
4
on:
June 27, 2011, 06:13:19 PM »
Hello,
I have a problem, I connected the serial port to breakout board, but when I run Mach3, there's no signal sending out through the breakout board, nor the serial port. Any one knows the reason?
Xiang
Carnoustie, Scotland
Re: Mach3 cannot send out signal
Reply #1 on:
June 28, 2011, 01:56:00 AM »
You need to use the parallel port rather than the serial port.
If you are using the parallel port then check you have the correct address set in Mach for it.
Tweakie.CNC
9,356
Super Kitty
Reply #2 on:
June 28, 2011, 01:57:27 AM »
Post deleted - I totally misunderstood the question.
Last Edit: June 28, 2011, 02:02:17 AM by Tweakie.CNC
Print
Pages:
1
Go Up
« previous
next »
