Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 11:39:32 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Why Reset two times?
Pages:
1
Go Down
« previous
next »
Author
Topic: Why Reset two times? (Read 294 times)
jafc76
Active Member
Offline
on:
June 24, 2011, 04:30:59 AM »
It's not a big problem, but I don't understand why I have to press Reset button two times to reset the limit switches of my new CNC router.
Any idea?
Thanks in advance
Active Member
Offline
Carnoustie, Scotland
Re: Why Reset two times?
Reply #1 on:
June 24, 2011, 05:19:21 AM »
Shouldnt have to, can you attach your xml as it may hold a clue.
jafc76
Active Member
Offline
Reply #2 on:
June 24, 2011, 05:47:04 AM »
Thanks Hood.
For your information, I'm using a smooth stepper using the two ports with two breakout boards.
Here you are
Mach3DMM.xml
(114.86 KB - downloaded 15 times.)
Active Member
Offline
Reply #3 on:
June 24, 2011, 06:04:44 AM »
Cant seem to find a problem as its working fine here. I did have to change the active state of the limits/homes and E-Stop as I am just simulating but as long as you dont have any LEDs for them on the diagnostics page you should be fine.
The other thing I did was change to the standard screenset as I dont have the 1024VFD.set that you use, so might be worth a try with that.
Other thing is if you have any brains or plugins (other than SS) being used it might be worth disabling them to see if they could be the problem.
jafc76
Active Member
Offline
Reply #4 on:
June 24, 2011, 06:14:15 AM »
Ok Hood, I will disable the plugins I use and we will see.
I'm using the Huanyang VFD RS485 plugin and the USB joypad v2.0 so maybe the problem is with something of this.
Thank you very much
Active Member
Offline
Reply #5 on:
June 24, 2011, 06:33:57 AM »
Please let us know if you find the issue.
BR549
Active Member
Offline
Reply #6 on:
June 24, 2011, 09:36:39 AM »
It is a switch bounce/ramp angle issue. I see it with a plasma table as well. When you go to back the axis off the limit it trips again then you hit reset again THEN you can back off the switch.
Just a thought, (;-) TP
jafc76
Active Member
Offline
Reply #7 on:
June 24, 2011, 10:13:09 AM »
Thank you BR549!
The switches are PNP proximity switches, and I use the PMDX-105 translator board because the signal is not good for my breakout board so it's like if I'm using a mechanical switch.
Tomorrow I will do some things to know if I can find a solution, now is too late here, I'm Spanish but living in Japan.
Thanks for your idea!!!
Juan
jafc76
Active Member
Offline
Reply #8 on:
June 24, 2011, 09:03:01 PM »
Today I was checking a few things.
My new machine is not finished so I'm doing some things. I was testing with the proximity sensors and one plate had a little bit of movement so maybe the sensor was detecting twice or more times.
I think it was the problem because after tighten the screws of the plate for sensor, I don't have that problem and when it's detecting, I have to reset only once.
Thanks Hood and BR549 for your help!!!
Juan
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
