Hello Guest it is June 12, 2026, 10:37:41 PM
Author Topic: Step and Direction input on Parker Compax servo  (Read 9294 times)
« on: June 22, 2011, 05:24:58 AM »
Can anyone help me with getting a Parker Hannifin (Hauser) servo system working with Mach 3.
I have a Compax 1060SL servo drive, which has a step and direction input mode. However, the manuals are very vauge/contradictory about the signals needed.
The interface can also be used for an encoder. I have tried 5V single ended signals and 5v double ended (RS422), but cannot get a response.
If anyone has experience of this, please let me know.
Colin
Re: Step and Direction input on Parker Compax servo
« Reply #1 on: June 22, 2011, 06:23:50 AM »
Just wondering if you have taken a common from your BOB to the drives as that will likely be needed.
« Reply #2 on: June 22, 2011, 06:34:05 AM »
Ok just looked at the manual, from a quick glance Pin 15 on X13 needs to be connected to your breakout boards Gnd so that the step/dir have something to be referenced to. You may already have done that though.
« Reply #3 on: June 22, 2011, 08:41:37 AM »
Thanks for the suggestion. When I tried the single ended connection, everything was powered/referenced to the controller. I wasn't using a breakout board, just a pulse generator.
Colin
« Reply #4 on: June 22, 2011, 10:01:00 AM »
Would seem to be your parameters are wrong then as according to the manual it should work fine.
