May 27, 2012, 11:27:08 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Brains Development
| | |-+  MPG with DYNOMOTION K-FLOP
Pages: 1   Go Down
Print
Author Topic: MPG with DYNOMOTION K-FLOP  (Read 1058 times)
Tubai
Active Member
Offline Offline
View Profile
« on: June 20, 2011, 09:53:53 AM »
Please Help!
I'm using a DYNOMOTION K-FLOP USB controller.
Recently trying to use a modbus MPG. Everything went fine if only the lpt driver is loaded.
Once installed the the K-FLOP .dll the MPG not work anymore. Asked the people from DYNOMOTION, but they do not know help.
In the brain view the MPG is working, the other buttons it's OK.
I need help!
Steve
Tubai
Active Member
Offline Offline
View Profile
« Reply #1 on: June 28, 2011, 09:10:54 AM »
I found the next plugin:
http://www.machsupport.com/forum/index.php?action=dlattach;topic=7784.0;attach=6129
With this installed works, bat shortly crash the system, I think there is a conflict with dynamotion plugin.
Why the MPG not work with brain, and work with plugin?
Pages: 1   Go Up
Print
Jump to:
