Hello Guest it is June 10, 2026, 09:40:04 PM
Author Topic: Z axis can`t Autozero the DRO  (Read 13836 times)
Offline kak
  •  81 81
« on: June 17, 2011, 02:37:28 PM »
It started today. After touching my touchoff plate, Z axis DRO always shows +269 in stead of 0. I mean in stead of 6.5 I set it to move up 6.5 after touching the plate. Auto zero is checked in config/home and limits.
I was playing with the button "set variable position" and "go to variable position" yesterday to see how it works.
Maybe this is the reason, but how can I fix that?
« Last Edit: June 17, 2011, 02:42:30 PM by kak »
Re: Z axis can`t Autozero the DRO
« Reply #1 on: June 17, 2011, 03:00:12 PM »
Do you have a Home Off value set?
Offline kak
  •  81 81
« Reply #2 on: June 17, 2011, 03:22:35 PM »
No, I don`t. Its 0
« Reply #3 on: June 17, 2011, 03:24:24 PM »
If you attach your xml I will see if I can find the problem.
Offline kak
  •  81 81
« Reply #4 on: June 17, 2011, 03:42:27 PM »
Its not easy to attach files. Ill try to zip it.
Offline kak
  •  81 81
« Reply #5 on: June 17, 2011, 04:08:23 PM »
I`ve found it:-)
The Gage Block High was set to +269.
This "set variable position" button is changing my touchoff plates thickness. I have try a few times. A bug?
« Reply #6 on: June 17, 2011, 04:13:22 PM »
Where is the Ser variable position?
Offline kak
  •  81 81
« Reply #7 on: June 17, 2011, 04:54:51 PM »
Its on the MDI ( Alt+2) screen
« Reply #8 on: June 17, 2011, 05:11:18 PM »
Seems to be working fine here, might be an idea to try a standard screenset to see if thats the issue.
Offline kak
  •  81 81
« Reply #9 on: June 17, 2011, 05:35:04 PM »
Thank you.
Right. Its not a standard screeenset. But the only one I could find with working edge and center finding macros.
Is there another options available?
