Hello Guest it is June 10, 2026, 03:01:17 AM
Author Topic: Help Please With Spindle  (Read 21843 times)
« on: June 15, 2011, 01:27:02 PM »
Can anyone tell me the meaning of the message on mach screen in status ?? it is saying scripter Compile Error in Spindle Speed.mis
if anyone can enlighten me it would be good. I took delivery of my mill which has been modified with belt drives and ball screws when I run the spindle this error is being shown I am new to spindle control via mach and such lost HELP
Re: Help Please With Spindle
« Reply #1 on: June 15, 2011, 02:17:36 PM »
Can you look in the macro folder for the profile you use and then copy and zip the spindlespeed.m1s macro and attach it to the forum.
« Reply #2 on: June 17, 2011, 08:33:20 AM »
sorry for taking so long been away- looked for that file and found it, not sure how to upload it but will try. I copied the file before zipping and had a look via notepad, now I know you should may not be  doing  this, I dont know how you look at these files officially?  but it has not alot in this that I can see. your thoughts.
Bob
hear we go for the upload
p.s had to rename it bobs
« Reply #3 on: June 17, 2011, 11:07:52 AM »
Ok what to do is open Mach then go to Operator menu then  VB Script Editor. In the window that pops up go to file and open then browse to your profiles macro folder and open the spindle speed macro. You will see
rpm = GetRPM()    SetSpinSpeed( rpm )
It should be on two lines like
rpm = GetRPM()
SetSpinSpeed( rpm )
Save it and hopefully you will be fine.
« Reply #4 on: June 22, 2011, 01:43:29 PM »
Hood thanks for that sorry for delay I tried what you said although the machine is not connected (away being worked on) but the two line you said were all on one line
hope this sorts it will tell by week end as machine comes back
Bob
« Reply #5 on: June 22, 2011, 01:55:05 PM »
No probs :) Hopefully thats all that the problem is .
« Reply #6 on: May 09, 2013, 04:51:22 AM »
I have the same problem, but I already edited my spindle speed macro and still get this error.
Anyone could help me please.
« Reply #7 on: May 09, 2013, 06:00:55 AM »
What version of Mach?
« Reply #8 on: May 09, 2013, 06:02:10 AM »
R3.042.020
« Reply #9 on: May 09, 2013, 06:07:37 AM »
And I have a Laptop with Mach3 without installed drivers, on it doesn't show that error, I have already put the exactly same configs on my PC that control the cnc and still show me this error, also, doesn't show me the complet toolpath draw.
