Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 11:16:22 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Spindle Problem and 2nd Parallel port issues
Pages:
1
Go Down
« previous
next »
Author
Topic: Spindle Problem and 2nd Parallel port issues (Read 257 times)
eartaker
Active Member
Offline
on:
June 14, 2011, 09:45:28 AM »
I have 2 separate issues that are driving me insane....
1. When I start the spindle in MDI so that I can jog the machine with my MPG to cut manually, the spindle just randomly stops. If the Machine is running with a g-code file it has no problems. I am using the CNC4PC 6axis MPG.
2. When I first boot up the pc that runs the mill Mach does not enable pins 1-9 for input even though the box is checked. I have to open pots/pins, uncheck the box, hit ok, then open ports/pins and re-enable it and then they will work.
Not sure what is causing all of this. Any ideas?
Active Member
Offline
Carnoustie, Scotland
Re: Spindle Problem and 2nd Parallel port issues
Reply #1 on:
June 14, 2011, 09:52:31 AM »
Can you attach your xml please.
eartaker
Active Member
Offline
Reply #2 on:
June 14, 2011, 10:25:48 AM »
Sure can...
PMDX_3Axis_pp_01.xml
(98.19 KB - downloaded 18 times.)
Active Member
Offline
Reply #3 on:
June 14, 2011, 01:02:16 PM »
Dont see anything wrong with the xml.
Does the spindle do the same when jogging via keyboard? If it does then disable the Brain for the MPG (if ther is one) and see if it still does it.
eartaker
Active Member
Offline
Reply #4 on:
June 15, 2011, 02:48:58 PM »
Turning the brain off does stop the issue but then I can not use my MPG. I can contact Art from CNC4PC about that but have any idea as to the 2nd parallel port input pins issue?
Active Member
Offline
Reply #5 on:
June 15, 2011, 03:32:40 PM »
Only thing I can think of is the port may be set to auto mode or possibly your xml is set as read only. If the latter is the case then Mach writes to the xml when you close Mach so it will try and write but if its set read only then it wont be able to, so next time you start Mach its back to the way it was.
You could try the save config setting in Mach, think its under Config menu. Change pins 2-9 as inputs and then save config and then look again to see if its still set, then try exiting Mach and restarting and see if its still set.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
