May 27, 2012, 11:09:53 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Set offset in Klaus' camera plugin?
Pages: 1   Go Down
Print
Author Topic: Set offset in Klaus' camera plugin?  (Read 248 times)
acieradave
Active Member
Offline Offline
View Profile
« on: June 11, 2011, 04:11:57 AM »
Hello everybody,
I just installed Klaus' Camera Plugin. Everthing works fine except that I can't figure out how to set the offset and that the coordinates don't show up when the box in the video window is checked. Any ideas?
Otherwise many thanks for the great work Klaus!
Klaus1311
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: June 11, 2011, 07:25:14 AM »
Hi Dave,
after start of Mach3 go to Config->Config plugins WebCamPlugin CONFIG. In that dialog you can set the X and Y-offset. Once the offset is set, open the "Dialog Settings" dialog on bottom of the camera screen. In that dialog you'll see the button "move offset". This button is only enabled, if Mach3 is not reset.
Klaus
acieradave
Active Member
Offline Offline
View Profile
« Reply #2 on: June 11, 2011, 07:37:28 AM »
Cool!
Works like a charm.
Thanks again Klaus
Pages: 1   Go Up
Print
Jump to:
