Hello Guest it is June 09, 2026, 11:22:28 AM
Author Topic: Program A axis to rotate as a Spindle  (Read 6283 times)
« on: June 10, 2011, 08:25:55 AM »
just added a 4 axis (" A axis" via a stepper motor to my system).
I want to turn it on so that it continues to rotate at a constant speed while Mach3 runs my program (g-code) instead of having to
Program each line with the "A *********.*********" code" to have the A axis spindle.
So how do I program the 4th axis to turn on at the beginning of my g-code file, then turn off at the end?
Any suggestions?  Thanks.
« Last Edit: June 10, 2011, 05:16:55 PM by RICH »
« Reply #1 on: June 10, 2011, 12:32:51 PM »
It is not possible using MACH in the NORMAL manner.
HOWEVER  IF you had a "manual spindle control " ( you turn it on/off by hand) you could set up the A axis to be run AS a spindle with step direction control. Speeds would be limited though.
Just a thought, (;-) TP
