Hello Guest it is June 10, 2026, 02:07:56 AM
Author Topic: Smooth Stepper Driver Problem  (Read 17419 times)
« on: June 10, 2011, 03:46:18 PM »
Can anyone help me on this one.  Running XP Pro, SS, PMDX-126 BOB, steppers.  When installing SS driver during installation I get the message "The file 'ftdibus.sys' on FTDI USB Disk is needed."  I can not find file and driver will not load correctly.  Help please!!!!!!!!!!!!!
Offline thosj
  •  542 542
Re: Smooth Stepper Driver Problem
« Reply #1 on: June 11, 2011, 05:55:18 AM »
You DO have the USB driver installed, correct?
Take a look here and scroll down to the SmoothStepper section and perhaps read thru the installation document, it's great.
http://www.soigeneris.com/Documentation-content.aspx
Tom
« Reply #2 on: June 12, 2011, 09:22:03 AM »
Greg at Warp9 helped me solve the problem.  Had to uninstall the driver (He sent me a file location to do so.) and then reinstall.  Deleting the file thru normal windows routines did not work.  All is well now.
Offline DonH
  •  19 19
« Reply #3 on: June 22, 2011, 04:02:12 PM »
Hi, I have the same problem.
Where is the file location?
Don
andrewm
« Reply #4 on: June 23, 2011, 01:06:10 PM »
Contact Greg at    support@Warp9TD.com and let him know the error message.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #5 on: June 24, 2011, 06:59:54 AM »
Here is the post Greg made on teh Warp9 forum that give the links to the new USB driver and the driver un-installer program.
http://www.warp9td.com/index.php?option=com_fireboard&Itemid=33&func=view&id=3012&catid=7#3012
Happy machining , Jeff Birt
Offline DonH
  •  19 19
« Reply #6 on: June 24, 2011, 04:48:19 PM »
Thanks Andrew, Jeff,
 I have swapped over computers at the moment but will see to it when I swap back.
Don
