Hello Guest it is June 09, 2026, 03:40:42 AM
Author Topic: How to write home function() in the motion plugin ?  (Read 6871 times)
« on: June 08, 2011, 09:17:23 AM »
how to write home function() in the motion plugin ?
Code: [Select]
extern "C" __declspec(dllexport) void Home( short axis ) ////////////////////  Called when Reset is pressed.
//Called when jog shoudl stop on a particular axis
AFX_MANAGE_STATE(AfxGetStaticModuleState( ));
Thanks !
Re: How to write home function() in the motion plugin ?
« Reply #1 on: June 13, 2011, 06:13:55 AM »
Hello to All !!!
Studied library for mach3 and came across a function HomeOn(int axis, int dir) , tried to use it but when you compile error is pointing to the wrong argument to an int dir. How correctly you can specify the direction of movement in this function?
i write this:
//axis   0-Xaxis,  1-Yaxis, 2-Zaxis, 3-Aaxis
//HomeOn(int axis, int dir)
TrajectoryControl->HomeOn(axis, ??????);
TrajectoryControl->GoHome;
« Reply #2 on: June 15, 2011, 01:42:38 PM »
the problem decided to myself :) do Not understand one moment , when the hit on the trailer and rode back up to its opening is reset to zero machine coordinate the axis .. how to do it until I understand.
