May 27, 2012, 10:53:28 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Machining time or run time
Pages: 1   Go Down
Print
Author Topic: Machining time or run time  (Read 187 times)
Jimildoo
Active Member
Offline Offline
View Profile
« on: June 06, 2011, 12:52:12 AM »
Is there a way to get an estimate of the runtime for a file once it is loaded into Mach3?
BR549
Active Member
Offline Offline
View Profile
« Reply #1 on: June 06, 2011, 01:43:51 AM »
SURE is go to the toolpath page and press simulate program run. That should give you the estimated run time.
(;-)TP
Jimildoo
Active Member
Offline Offline
View Profile
« Reply #2 on: June 06, 2011, 01:55:17 AM »
Doh! Smiley Thats good - I knew it had to be there somewhere, but there isnt any reference I could find in the documentation. Thanks.
Pages: 1   Go Up
Print
Jump to:
