Hello Guest it is June 10, 2026, 11:14:15 AM
Author Topic: Random Estoping Kinda  (Read 18416 times)
« on: June 03, 2011, 05:51:02 AM »
i have tried everthing in the forum for this issue and still cant fix it . problem is when i activate the y and z limits i cant clear the estop as mach is saying there is a limit switch triggered. but in the diagnostics page none of the l.e.d. are lit. all the switches perform as expected,
-Only happens when y and z limit inputs are active
-they are all wired with shielded cable.
-wired to be active high (y and z)
-tried disabling watch dog and set the debounce interval up to 10000 and no help
-when selecting the Automated setup of inputs and doesent matter what input that is selected mach picks up a signal from port 1 pin 0,
So as far as i know the is no pin 0?  i don't get it. all my electronics are from keling.
Re: Random Estoping Kinda
« Reply #1 on: June 03, 2011, 09:25:27 AM »
What does it show in Config /pins/ports about what the settings are for the limits?
Just a thought, (;-)TP
« Reply #2 on: June 03, 2011, 05:04:38 PM »
were u able to open the videos that shows the input page?
« Reply #3 on: June 03, 2011, 05:05:10 PM »
Can you attach your xml please.
« Reply #4 on: June 03, 2011, 05:30:43 PM »
not sure exactly what that is?
« Reply #5 on: June 03, 2011, 05:32:13 PM »
going to buy a new pci adapter for the computer tonight to try
« Reply #6 on: June 04, 2011, 12:53:39 AM »
the xml is the file that holds your configuration settings, you will find it  in the main Mach 3 folder and it will have the name of the profile you are using and have an xml extension.
« Reply #7 on: June 04, 2011, 04:08:42 AM »
cant get the file to upload here. so i posted it on buildyourcnc.com forum
« Reply #8 on: June 04, 2011, 04:26:26 AM »
You use the additional options button on the reply page to attach files, you may have to rename them or zip  as the forum will only accept a name once.
Either that or provide a direct link to where you posted it on that other forum as I am not familiar with it.
