Hello Guest it is June 10, 2026, 10:45:01 PM
Author Topic: 8 position lathe toolchanger  (Read 23658 times)
« on: June 01, 2011, 05:12:48 AM »
Hi all
I am in the early stage of converting  an Emcoturn 120
to Mach control and at the moment I am looking at the toolchanger
it appears to be a really well made bit of kit (see photos)
It is a pawl design with a spring loaded pin used for location
meaning it can only rotate in one direction ( although the manual I
have says it can move either direction but I cant see any method for
retracting pin so I think it may be for a later version unless someone
out there can put me right) The turret position is controlled by 4 sensors
and cutaway vane which produces 4 output signals shown in the table.
Movement is via a small dc motor controlled by an emco board.
It is my intention to change the dc motor with a stepper and have a fast
rotate followed by a slow reversed rotate to lock pin as I have seen a
macro on the forum to tackle this type of setup. I have also seen another
macro setup to handle pin position input. (with if possible including the
option of a manual selector or rotate switch)
I have some user experience of mach3 mill but none of mach3 turn
and this if my first venture into the nuts and bolts of system setup.
I would like to be able to either modify existing programs or write
new to suit but dont have any knowledge of vb script .Can anyone
out there tell where I can find list of commands and construction rules
or recommend a book. As this is a skill I would love to master.
Also I am  a bit lost at the moment on how to convert the sensor
output results (see table) so mach knows that for example
1011 is position 5
any help would be greatly appreciated
cheers George
  •  9,356 9,356
Re: 8 position lathe toolchanger
« Reply #1 on: June 01, 2011, 06:47:53 AM »
The Visual Basic version used is Cypress Enable and the commands and syntax in PDF format can be downloaded from here;
http://www.machsupport.com/forum/index.php?action=dlattach;topic=18062.0;attach=26020
Also Scott's Mach specific routines here;
http://www.machsupport.com/forum/index.php?action=dlattach;topic=11056.0;attach=14194
http://www.machsupport.com/forum/index.php?action=dlattach;topic=11061.0;attach=14193
Hope this helps,
« Last Edit: June 01, 2011, 07:00:14 AM by Tweakie.CNC »
« Reply #2 on: June 01, 2011, 07:40:36 AM »
thanks Tweakie thats exactly what I was looking for.
now the learning curve begins
cheers george
« Reply #3 on: June 01, 2011, 09:36:43 AM »
Might want to consider using the TC as is. Obviously it worked well ???  Just need to work out the control.
Just a thought(;-) TP
« Reply #4 on: June 01, 2011, 10:31:01 AM »
Hi TP
Was looking to change to stepper motor as I don't think I have the electrical ability to work out dc motor drive control.
Stepper approach seems more achievable (for me)
However if anyone out the has already integrated an Emcoturn 120 turret I would love to hear from them.
I'm all in favour of saving some money
Cheers George
« Reply #5 on: June 01, 2011, 11:49:47 AM »
Check with TANTAN here:  http://www.machsupport.com/forum/index.php/topic,5718.10.html
Looks like he has converted one with Tool changer.
« Reply #6 on: January 25, 2017, 03:21:30 PM »
HI Bigwing
I also have a turn 120.  I would like to know how much voltage is used for the sensors and on what pins it uses.
Penguinair ;)
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #7 on: January 26, 2017, 06:20:06 AM »
There is a M6Start.m1s on here somewhere to run that tool changer using the DC motor I know this because I did the code for it.
« Reply #8 on: January 26, 2017, 11:37:37 AM »
Hi Penguinair
I am not the best person to ask as my Electrical knowledge is very limited.
I read the diagram (may be wrong but see sensor outputs attachment above) as 24v supply but I was not able to
correctly decipher the pin outs and managed to smoke my board. !!**@@**!! The price for a replacement from
Emco was circa £300 GBP  So I managed to replicate the boards function using off the shelf parts for about £5 GBP
(see attachments) Basically it is just 4 photo interrupter sensors used to produce the output signals. The schmitt
trigger inverter conditions the output to be either 0 or 1 nothing in between. Note the attached diagram only shows
the circuit for one sensor obviously the complete circuit requires four. The outputs were sent via a pokeys  to a tool turret brain.
(see working solution @ machsupport forum/mach discussion/brains development /" compare immediate not working" BIGWING
www.machsupport.com/forum/index.php/topic,30316.0.html
This program followed the truth table to give a value for the current tool which I used in my modified M6Start.mls program
to index the turret.
However I am aware that there is a ready made control solution to the emco tool turret with a complete integrated package
in mach. I think the developers name is Andy Barrow. I think the company name is barrow dynamics but I might have my wires crossed there.
Best idea is to google it. I am sure if you get in touch with him he will know what the correct pin outs are for the Emco board
and save you a lot of work.
Cheers George
« Reply #9 on: January 26, 2017, 12:03:47 PM »
BIGWING
THANKS FOR THE HELP.
RICHARD
