Hello Guest it is June 10, 2026, 10:45:50 PM
Author Topic: 1 axis jog=smooth 2 axis jog= rough?  (Read 26706 times)
Re: 1 axis jog=smooth 2 axis jog= rough?
« Reply #20 on: June 09, 2011, 10:30:07 AM »
That is the blended speed you are seeing, if you jog a single axis or command a diagnonal move with a G1 and a Feed of 130 it will move at 130.
« Reply #21 on: June 09, 2011, 10:52:12 AM »
oh i see.
i just thought the max being at 130 it would do that diagonally too.
thanks
« Reply #22 on: June 09, 2011, 10:57:56 AM »
The max is 130 per axis but because its travelling diagonally it is moving a further distance so the blended  feedrate will be higher.
« Reply #23 on: June 09, 2011, 05:07:20 PM »
gotcha
« Reply #24 on: June 09, 2011, 05:17:04 PM »
But as said earlier if commanding a feedrate on a diagonal then that would be what you get, ie X and Y would move slower so that the blended feedrate was correct.
« Reply #25 on: June 09, 2011, 05:46:53 PM »
ya, that makes sense.
i got a smoothstepper ordered and will see how awsome it can make my machine. >:D
