Hello Guest it is June 12, 2026, 05:29:45 AM
Author Topic: Shuttle_RU  (Read 6800 times)
Shuttle_RU
« on: May 25, 2011, 11:57:10 AM »
   Just received a Shuttle_RU from Andrey. I am not too computer literate and need some help. By the way this is a great looking unit. I am running a Tormach PCNC1100 mill with Mach3. I loaded the Shuttle_RU into the Mach3 plugin file and when I go to config in Mach3 I do not find the file.
  I am sure that I am doing something wrong or not doing something that I should be doing. If anyone could pass on a step by step procedure I would appreciate it.
          Ernie
Re: Shuttle_RU
« Reply #1 on: May 25, 2011, 12:39:43 PM »
If the file is a m3p extension you will need to double click on it so it installs properly, if its a dll then it should just need placed in the plugins folder. You will have to restart Mach after installing it and also you may need to restart Mach after enabling it in the plugins list (if you find it)
If you still cant get it then it may be something to do with Tormach as I think they use an OEM version of Mach that has some restrictions on user adjustments, so ask Tormach and see if they can help if you still have issues.
