Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 27, 2012, 10:20:44 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
HELP! My Z axis is moving in chunk steps
Pages:
1
Go Down
« previous
next »
Author
Topic: HELP! My Z axis is moving in chunk steps (Read 323 times)
curtisturner
Active Member
Offline
on:
May 24, 2011, 09:41:08 AM »
Here is the problem.
I have a 4th axis machine where A is the chuck X moves the length of the object being machined and Z is the depth.
The A axis keeps a perfect continuous RPM and the X axis is moving constantly at say the rate of 128th of an inch per second and the servo motor for the X has a constant smooth rotation. However the Z axis servo is not moving except every few seconds and it then moves about 10deg instead of much smaller say 1/2 deg steps. Is there a setting I am missing or is my G-Code wrong?
A Few Facts
All 3 axis are Yaskawa Servos
Z axis is a ball screw driven by a 10:1 gearhead
Here are a few line of G-Code
N000035 A1440 X0.077 Z-0.00281176075414713;
N000036 A1440 X0.077 Z-0.00285099436525282;
N000037 A1440 X0.077 Z-0.00288965724492307;
N000038 A1440 X0.077 Z-0.00292777388626453;
N000039 A1440 X0.077 Z-0.00296536717817242;
N000040 A1440 X0.077 Z-0.00300245854969372;
N000041 A1440 X0.077 Z-0.00303906809810783;
N000042 A1440 X0.077 Z-0.00307521470288652;
N000043 A1440 X0.077 Z-0.00311091612742498;
N000044 A1440 X0.077 Z-0.00314618911008591;
N000045 A1440 X0.077 Z-0.00318104944591235;
N000046 A1440 X0.077 Z-0.00321551206015691;
N000047 A1440 X0.077 Z-0.00324959107459355;
Thanks in advance
Curtis
curtisturner
Active Member
Offline
Re: HELP! My Z axis is moving in chunk steps
Reply #1 on:
May 24, 2011, 12:08:44 PM »
Majke one more mention, the DRO for Z axis shows slow continuous motion
Active Member
Offline
Carnoustie, Scotland
Reply #2 on:
May 24, 2011, 03:30:20 PM »
Is it ok if you command a Z only move?
Not really sure what you are meaning when you say Z moves 10deg steps, Z is normall a linear axis.
What are your steps per unit for the Z
Sage
Active Member
Offline
Reply #3 on:
May 24, 2011, 04:00:50 PM »
Had me confused as well. I think what he's saying is the shaft of Z servo moves only 10deg at a time. Shaft turns pulley, pulley drives Z-axis linearly.
I'm wondering if it's simiilar to the issue that I was helped with which turned out to be turning on exact stop instead of constant velocity (or maybe it was the reverse)?
Sage.
curtisturner
Active Member
Offline
Reply #4 on:
May 24, 2011, 09:38:08 PM »
Yes the shaft that is between gearhead and ballscrew.
Or in other words the Z axis is moving 0.00292777388626453 in one move not slowly as the other 2 axis are
even if I run the G01 in front of each line that does not help
2 out of 3 axis seem to provide smooth linear interpolation.
To better understand I am machining the outside surface of a cone shaped fiberglass shell starting at the biggest diameter and working down to the smallest while the A axis is spinning. The real problem is it is leaving machining marks every time the Z axis lowers.
I have G64 in the start line
Active Member
Offline
Reply #5 on:
May 25, 2011, 09:19:24 AM »
As said earlier, what are the steps per unit of the Z and does it perform fine if a Z only move is made?
curtisturner
Active Member
Offline
Reply #6 on:
May 25, 2011, 11:21:18 AM »
Yes the Z axis moves smooth if the line looks like this
N1000 Z 1.00;
Here are all my Motor settings
Z
Steps = 50911
IPM = 53.034
Accl = 2000
X
Steps = 1015.4
IPM = 49.99
Accl = 2000
A
Steps = 56.89
IPM = 6666 (is truely degrees of rotation)
Accl = 80000
Thank You
Curtis
Active Member
Offline
Reply #7 on:
May 25, 2011, 12:31:12 PM »
In the above code can you edit to remove the A and X moves just leaving the Z moves and see if the same happens. You are not moving A and X so it would be interesting to see if the Z still stutters with them removed. Your motion is very small and it could possibly be your tuning.
curtisturner
Active Member
Offline
Reply #8 on:
May 25, 2011, 01:16:37 PM »
Ok tried it with 20 lines and had to slow it way down, because 20 line is only about 1/16 of an inch.
With out it being slowed down it went real fast on fast movement
After slowing it down it readover half the line before it even moved at all.
So I then tried to make the movement a lot larger like .1 inch each and it still chunked the movements instead of a smooth fluid motion.
Is there a setting I am missing ?
BTW, it jogs very smooth and it you tell it in Gcode to move by it self up and down inches it is very smooth and continuous
Thank You
Curtis
Active Member
Offline
Reply #9 on:
May 25, 2011, 01:28:05 PM »
It sounds to me as if your tuning may be very loose and the axis (with gearhead) may have some stiction.
If you attach your xml I will have a look but as the DROs in Mach move smoothly I would say it is more likely your servo tuning or possibly even the drive parameters.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
