Hello
Guest
it is
June 09, 2026, 03:40:52 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Do step & direction wires need to be shielded cable?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Do step & direction wires need to be shielded cable? (Read 8006 times)
Jackal
173
on:
May 23, 2011, 04:15:42 PM »
It's time for the step & direction wires from the B_O_B to the Geckos.
Do these need to be shielded cable?
If so, what gauge?
I have some of the shielded cable left from the factory wiring. It's not very heavy gauge.
JAckal
Everything is bio-degradable if you run over it enough with a lawnmower.
Carnoustie, Scotland
Re: Do step & direction wires need to be shielded cable?
Reply #1 on:
May 23, 2011, 04:42:29 PM »
Dont need to be heavy, not sure of your USA gauges but just signal wiring is needed but definitely shielded in my opinion.
Jackal
173
Reply #2 on:
May 23, 2011, 04:44:11 PM »
Would encoder wire work?
JAckal
Reply #3 on:
May 23, 2011, 05:20:30 PM »
Would be perfect, encoder signals and step/dir signals are basically the same thing
Print
Pages:
1
Go Up
« previous
next »
