May 27, 2012, 10:18:50 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Macros in Addons???
Pages: 1   Go Down
Print
Author Topic: Macros in Addons???  (Read 366 times)
giannis121
Active Member
Offline Offline
View Profile
« on: May 23, 2011, 06:21:42 AM »
Do Addons have macros???
If yes, where can i place my own macro? (Which folder)
(I have created a button inside an Addon, that i want to run a macro.)
Thank you,
Giannis
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #1 on: May 23, 2011, 05:11:12 PM »
The macro is saved in the button. Choose Operator > Edit button script, and save the macro there.
giannis121
Active Member
Offline Offline
View Profile
« Reply #2 on: May 24, 2011, 01:47:05 AM »
My real problem is not that.
The code contains a MSGBOX and the message is written in my language.
So, although the first time the message appears, if i open the button to edit it, the letters become questionmarks.
Exactly the same happens in the main screen of Mach.
So, if i put my code in a macro (it is tested in the main screen) the message appears as well.
Finally my question is where is the "macro" folder for the addons....
Thank you...
Giannis
Pages: 1   Go Up
Print
Jump to:
